Kenmore Laundry Center - Is the drain hose from the tub to the pump replaceable? I am baffled at this point as to how to remove it from tub. Thank You :confused:
remove two clamps and hose that goes to pressure switch.
There is only one clamp on this hose at the pump. Maybe there's a nut and washer/ gasket on the hose inside the tub?
