Donny C
#1 Posted : Tuesday, February 24, 2009 1:00:10 PM(UTC)
Donny C
Of course, my warranty is up. First the broiler just shut down, no warning, mid broil. The convection oven seemed to be ok when I turned it on, the fan started up ok. But that shut down within a minute. The gas stove top portion works fine. Suggestions?
TechnicianBrian
#2 Posted : Tuesday, February 24, 2009 4:17:16 PM(UTC)
TechnicianBrian
A model number would be most helpful. If it is only the oven that is no longer working, I would suspect a thermal fuse has opened the L2 circuit to the elements. It is usually located behind the control panel with a red reset button.
Donny C
#3 Posted : Wednesday, February 25, 2009 7:27:14 AM(UTC)
Donny C
Thanks Brian
A contractor friend with the right tools tried to get into the control panel, located behind the control knobs on the front. I need to get off the control knobs because there seem to be screws that originate behind them and go through the front of the panel and into little L brackets to hold it on. Kind of a nifty lock to keep me out, is the way I look at it. I will be sooooooo p-ed if I have to pay $200 for someone to come and hit the reset. The $200 is what the repair service around here charges just for "diagnostics".
Any further suggestions on getting down in there?
TechnicianBrian
#4 Posted : Wednesday, February 25, 2009 4:27:52 PM(UTC)
TechnicianBrian
You still haven't provided a model number so I am not entirely sure what you are looking at, but in many cases, there are some screws behind a couple of the knobs that go through the bezel and into a bracket holding the panel place. As for paying for a diagnosis, if someone does come out and reset the thermal fuse, I would expect them to also figure out why it happened. May be a fluke, but if a safety component trips, I like to figure out why.
Bosch dual fuel range burners all spark but 2 burners don't ignite (Oven Repair (including Ranges and Cooktops))
by elizabeths 2/24/2021 8:16:50 AM(UTC)
Kitchenaid dual fuel range - display and oven dead, burners working (Oven Repair (including Ranges and Cooktops))
by cliffo 12/2/2020 7:38:02 AM(UTC)
THERMADOR 36" Dual Fuel Range (Oven Repair (including Ranges and Cooktops))
by jascato 11/27/2013 9:09:37 PM(UTC)
Jenn-Air dual fuel range (Oven Repair (including Ranges and Cooktops))
by Stever1951 11/26/2013 5:35:22 PM(UTC)
Electrolux dual fuel range oven will not heat (Oven Repair (including Ranges and Cooktops))
by p.andrew 3/19/2013 8:47:44 AM(UTC)
Sears Kenmore Pro Dual Fuel Range Problem Up (Oven Repair (including Ranges and Cooktops))
by akkelley3 10/31/2012 5:38:47 PM(UTC)
Sears Kenmore Pro Dual Fuel Range Problem Heating Up (Oven Repair (including Ranges and Cooktops))
by akkelley3 10/28/2012 2:08:03 PM(UTC)
Thermador Dual fuel range oven door locked and f3 code. (Oven Repair (including Ranges and Cooktops))
by mikey77 7/28/2012 7:14:51 AM(UTC)
kenmore pro dual fuel range overheating (Oven Repair (including Ranges and Cooktops))
by kenmoreprofails 5/1/2012 5:28:38 PM(UTC)
Dacor Dual Fuel Range Beeps & Shuts Off (Oven Repair (including Ranges and Cooktops))
by Coolhand 3/26/2012 5:05:13 AM(UTC)
How to repair Jenn air Dual fuel range (Oven Repair (including Ranges and Cooktops))
by storm965 10/13/2011 5:14:59 AM(UTC)
Kitchen Aid dual fuel range, oven doesn't work (Oven Repair (including Ranges and Cooktops))
by bkvanbek 9/26/2011 5:16:43 PM(UTC)
Thermador dual fuel range (Oven Repair (including Ranges and Cooktops))
by gmg3 2/9/2011 8:46:50 PM(UTC)
Frigidaire dual fuel range (Oven Repair (including Ranges and Cooktops))
by mcedison 11/11/2010 9:15:34 AM(UTC)
kenmore Dual Fuel Range - oven does not heat (Oven Repair (including Ranges and Cooktops))
by richardjefferson 10/3/2010 7:45:47 PM(UTC)
