cecelo
#1 Posted : Tuesday, January 17, 2012 6:57:16 AM(UTC)
cecelo
Upper Convection Oven will not heat up to the correct temperature. It will "buzz" that it is "ready" but its hasn't reach the right temperature; not hot enough. Lower oven (not convection works fine).
#2 Posted : Wednesday, January 18, 2012 3:00:59 AM(UTC)
I could not find any info on the given model number.
Sounds like it may be an oven sensor problem.
Here is a good link, check out 7, 8, 20 and 21.
http://www.applianceaid.com/elecrange.html
If the sensor checks out OK then odds are that the control board is toast.
If it is an old unit that uses a thermostat then I would replace the thermostat.
