2 Pages12>
paul888
#1 Posted : Monday, January 16, 2012 1:37:57 PM(UTC)
paul888
Have A Hotpoint Dryer - Mod.# Nwsr483eb3ww That Won't Start Up...replaced Timer....checked Door Switch With Meter..seems To Be Ok...problem Started When I Was Replacing Felt And Belt ....had Back Panel Opened ( Where Switch Wires Connect To Switches ) And Inadvertenly Shorted Brown Wire Going To Timer Out On Back Panel And On Top Of Timer At The Same Time. Figured It Was Timer - So I Replaced That...still Won't Start Up...any Help ????? Could It Be The Resistor " Ap2044425 "??? How Can I Check To See If It Was Shorted Using A Meter??what Should The Value Be ??
#2 Posted : Monday, January 16, 2012 4:55:19 PM(UTC)
I hope you will never ever work with any appliance which is still under power.
The first thing I would do is check for continuity the thermal fuse (#507 on the diagram).
- The thermal fuse Part number: AP2042565
paul888
#3 Posted : Tuesday, January 17, 2012 3:51:20 AM(UTC)
paul888
Thanks Gene For Your Help :) ... At The Thermal Fuse # 507 I Have Continuity...now What???
#4 Posted : Tuesday, January 17, 2012 1:42:45 PM(UTC)
Did you check the circuit breakers and the voltage to the dryer?
paul888
#5 Posted : Wednesday, January 18, 2012 5:09:33 AM(UTC)
paul888
LIGHT COMES ON WHEN I OPEN DOOR..SO I FIGURED POWER WAS GOOD - BUT I RESET BREAKER JUST TO MAKE SURE...STILL NO GOOD. I AM INCLINED TO THINK ONE OF THREE THINGS IS BAD. 1)START SWITCH 2)DOOR SWITCH OR 3) THE RESISTOR UP ON THE TOP CONTROL PANEL. DOES THE POWER TO RUN THE DRYER MOTOR COME OFF THE DOOR SWITCH ? I HAVE 120V GOING TO DOOR SWITCH (CHECKED WITH METER). AS A TEST - IF I USED A JUMPER WIRE TO JUMP THE POWER -120V GOING TO THE DOOR SWITCH - TO THE BROWN WIRE COMING OFF THE DOOR SWITCH THAT GOES TO THE MOTOR, THUS BYPASSING SWITCH - SHOULD THE MOTOR START ?:confused:
#6 Posted : Wednesday, January 18, 2012 1:36:29 PM(UTC)
Paul,
Did you see the wiring sheet inside the control panel?
If you found it, can you post it here?
paul888
#7 Posted : Thursday, January 19, 2012 4:33:18 AM(UTC)
paul888
here it is...if i did it right !!
paul888 attached the following image(s):
#8 Posted : Thursday, January 19, 2012 1:44:36 PM(UTC)
This is exactly what I needed.
Check the idler spring switch (#803 on the diagram) and the belt. Post the results.
- The switch Part number: AP3994765
paul888
#9 Posted : Friday, January 20, 2012 3:31:25 AM(UTC)
paul888
idler switch has continuity and belt is new
paul888
#10 Posted : Friday, January 20, 2012 3:37:21 AM(UTC)
paul888
Also What Does The " Overload Protector " Look Like Between The Motor And Door Switch ??
Guest (11)
Kenmore Elite dryer won't run... (Dryer Repair)
by J C Jones 9/11/2021 9:09:42 AM(UTC)
Kenmore Dryer won't run (Dryer Repair)
by gman536 3/14/2021 3:37:08 PM(UTC)
Dryer won't run unless start button is held down - no heat (Dryer Repair)
by jstrefeler 9/24/2017 12:10:11 PM(UTC)
Dryer WOn't Run (Dryer Repair)
by wstvpawjr13 5/14/2017 12:23:41 PM(UTC)
Dryer won't run after releasing the on button (Dryer Repair)
by Heathers1988 11/9/2016 4:20:53 PM(UTC)
Amana Dryer won't run (Dryer Repair)
by Paige Tremblay 1/26/2014 6:06:08 AM(UTC)
dryer won't run (Dryer Repair)
by dymetz62 1/8/2014 5:00:20 PM(UTC)
by pmclaughlin@apins.com 4/9/2013 11:18:38 AM(UTC)
by Ronald Walls 3/19/2013 1:09:09 PM(UTC)
by Ronald Walls 3/19/2013 1:06:28 PM(UTC)
by loumemoli 7/2/2012 1:33:54 PM(UTC)
dryer won't run but heats up fast (Dryer Repair)
by w. carroll 3/28/2012 8:22:26 AM(UTC)
Dryer won't run after start. (Dryer Repair)
by clparks 4/28/2011 9:49:25 AM(UTC)
by tterry 3/29/2011 10:49:47 AM(UTC)
by DarrelD 1/31/2011 1:09:02 PM(UTC)
2 Pages12>
