Dolores814
#1 Posted : Friday, January 13, 2012 10:36:05 AM(UTC)
Dolores814
Just received replacement part from you and have installed. Am concerned the element was all that was wrong w/range and not some other internal problem. Am asking because when I turned the element on just 325 degrees, it glowed bright orange and really emitted heat. I don't remember how it looked or seemed before it needed to be replaced. Am I just worried for no reason since I didn't get an expert (and pay a hefty fee) to install? Thanks for any help you can offer.
PS I was very pleased with price and delivery of item ordered from you.
Dolores814
#2 Posted : Friday, January 13, 2012 10:39:26 AM(UTC)
Dolores814
I am new to this type of on-line interaction; I hope I've done this correctly.
#3 Posted : Friday, January 13, 2012 1:12:02 PM(UTC)
Sounds OK to me.
You could get an oven thermometer to see if the oven temperature is accurate.
Oven elements are cycled off and then full on. They do not regulate the amount of heat given off by the element but regulate how long it stays on (cycles).
Once the unit hits set point temperature you may not see it get red because it is bringing the oven temperature back to set point in less time than it takes the element to turn red.
GE oven bake element (Oven Repair (including Ranges and Cooktops))
by 72yrsoldwoman 10/27/2023 6:22:03 PM(UTC)
Whirlpool oven bake element doesn't come on (Oven Repair (including Ranges and Cooktops))
by Gotzman 1/16/2016 8:41:52 AM(UTC)
ge oven bake element will not turn off (Oven Repair (including Ranges and Cooktops))
by rgaden 8/20/2014 9:51:39 AM(UTC)
Kenmore Elite Oven bake element not heating (Oven Repair (including Ranges and Cooktops))
by ADN140 12/16/2013 12:24:26 PM(UTC)
Oven bake element works sometimes (Oven Repair (including Ranges and Cooktops))
by tallshouse 3/4/2013 7:05:10 AM(UTC)
Oven Bake Element (Oven Repair (including Ranges and Cooktops))
by JMAL 4/25/2012 8:47:14 AM(UTC)
oven bake element required (Oven Repair (including Ranges and Cooktops))
by Olga-C 4/20/2012 10:04:16 AM(UTC)
Attempting to install a oven bake element (Oven Repair (including Ranges and Cooktops))
by livelifeest1973 3/9/2012 12:36:51 PM(UTC)
by carguy50 2/23/2012 1:55:12 PM(UTC)
GE oven bake element not working, broil works. (Oven Repair (including Ranges and Cooktops))
by HelpMeAnyone 12/25/2011 3:39:09 PM(UTC)
Oven bake element lead (Oven Repair (including Ranges and Cooktops))
by Ctwild 12/5/2011 4:33:39 AM(UTC)
Oven Bake element not working (Oven Repair (including Ranges and Cooktops))
by NickJade 11/14/2011 8:17:42 AM(UTC)
Oven bake element does not heat (Oven Repair (including Ranges and Cooktops))
by crna1 7/5/2011 11:18:31 AM(UTC)
Magic Chef oven bake element (Oven Repair (including Ranges and Cooktops))
by Rafat 6/29/2011 11:42:53 AM(UTC)
by pls418 5/3/2011 6:19:41 PM(UTC)
