TITANICHISPANIC
#1 Posted : Monday, January 9, 2012 6:41:12 PM(UTC)
TITANICHISPANIC
dryer drum would not turn
belt broken but the pulley at the end of te motor was cracked into 2 pcs whic is what broke the belt. im trying to order that pulley and cannot identify it help
TITANICHISPANIC
#2 Posted : Monday, January 9, 2012 6:43:25 PM(UTC)
TITANICHISPANIC
aby body help
#3 Posted : Tuesday, January 10, 2012 2:10:38 AM(UTC)
I do not work for AppliancePartsPros so it is probably best to double check this.
Anyway I looked at the parts for this unit.
Here is that parts breakdown.
Replacement parts for MAYTAG PYGT244AWW DRYER- GAS | AppliancePartsPros.com
There was no motor pulley listed.
I then clicked on the motor (Item 1 in Section 5), a new page opens with more views and a Q&A section.
The last question in that section was about the pulley and had the following info for a pulley part number.
Part number: AP4038987
With luck this is for your machine though I do not see how it is held onto the motor shaft.
