mattsegawa
#1 Posted : Monday, November 12, 2007 3:34:50 PM(UTC)
mattsegawa
Looking for install instructions from front left spark electrode for this model.
Thank you!
m
mattsegawa
#2 Posted : Sunday, November 18, 2007 12:59:37 PM(UTC)
mattsegawa
Any word on this question. Install instructions fro the spark electrode. Thank you
#3 Posted : Monday, November 19, 2007 11:45:54 AM(UTC)
Remove the burner cap. Remove the two screws, holding the burner.
If they are rusted in then you have to drill them out and order a new screws.
Lift the burner and remove the igniter from the burner. Cut the wire about 10" from the old igniter (do not let the wire to fall). Cut the wire about 10" from the new igniter and put the wire from the new igniter through the hole in the burner.
Connect both wires, using a ceramic high temperature wire nut.
Assemble the burner in the reverse order.
- The part number for the screw AP3126303
- Here are the break down diagrams for the Whirlpool range Model SF395LEEQ0
