stodtmeister
#1 Posted : Sunday, November 18, 2007 11:29:34 AM(UTC)
stodtmeister
My dryer isn't drying like it should. I have to run it 3 or 4 times to get my clothes to dry. The lint trap is clean and I pulled the dryer apart and cleaned all of the lint out so I don't think it is an airflow problem but I'm not sure if it's a thermostat problem or the heating element. Can it partially burn out? Any help would be appreciated. Thanks.
#2 Posted : Monday, November 19, 2007 10:29:20 AM(UTC)
Most likely the problem is the clog vent outside the dryer.
Disconnect the vent hose from the dryer and run a couple of loads with the hose being disconnected.
Post your findings, please.
stodtmeister
#3 Posted : Tuesday, November 20, 2007 10:25:29 PM(UTC)
stodtmeister
I tried that when I cleaned everything out and got the same result. The exhaust runs from the back of the dryer through the wall and that's it so I've only got about a foot of duct work from the back of the dryer.
smokeyfl
#4 Posted : Wednesday, December 12, 2007 4:12:41 PM(UTC)
smokeyfl
just using this site for the first time, have the same issue with my maytag dryer, did you find a solution for your issue?
