3 Pages123>
reggier
#1 Posted : Saturday, December 31, 2011 1:58:48 PM(UTC)
reggier
I have a question about repairing my freezer. It is a hotpoint refrigerator / freezer. Model is HSM25GFTASA. I have two problems. First one that started was the ice dispenser does not always give you the correct ice crush vs. cubed. Seems to give you one or the other. The second and more important problem is the freezer is now building up frost on the outside of items in the freezer. Also, on the shelves, their is a buildup of frost/ice. Seems like things in the freezer start to melt and then freeze again. This is also causing the ice to melt some and then freeze into chunks.
I assume this is some sort of a problem with the defrost mode?
I was looking for help in determining where the parts are that need to be checked. How to check them to determine which is bad so that I can order the correct part to fix the problem.
richappy
#2 Posted : Monday, January 2, 2012 3:16:25 AM(UTC)
richappy
Remove the freezer back panel and check the frost pattern, if completely heavy ice, defort with ahair dryer. Post the freezer temperature once it is running a while.
reggier
#3 Posted : Monday, January 2, 2012 10:49:26 AM(UTC)
reggier
I checked the coils inside the freezer behind the panel. They have frost on them. Not sure if any frost is normal or not. I'm including a picture so that someone can tell me if this much frost is acceptable.
I unplugged the freezer and let everthing defrost. Once defrosted, I wiped up the water and plugged back in the freezer. After one day, the coils have frost on them again.
I can't find a thermometer to test the temperature inside the fridge. Ice is in the ice maker and is normal at the moment.
reggier attached the following image(s):
richappy
#4 Posted : Monday, January 2, 2012 3:48:39 PM(UTC)
richappy
Picture looks normal to me, post the freezer temperature.
reggier
#5 Posted : Thursday, January 5, 2012 5:49:46 PM(UTC)
reggier
It took a while for me to respond. I got a thermometer and the temperature in the freezer was between 12 and 14 degrees.
The freezer temperature setting is set to 6.
richappy
#6 Posted : Friday, January 6, 2012 12:29:55 AM(UTC)
richappy
The freezer temperature is too warm, if that is the lowest temperature the freezer can get down to. Check the condensing fan in the back and the condensing coils.
reggier
#7 Posted : Friday, January 6, 2012 4:19:03 AM(UTC)
reggier
I checked the temperature again this morning. The temp was -8 degrees. Thermometer has been in there for about 12 hours. My first report of temp only had the thermometer in there for an hour.
Is -8 the correct temp?
richappy
#8 Posted : Friday, January 6, 2012 6:47:18 AM(UTC)
richappy
Your refrigeration system is ok. Seems like your compressor may be intermittent.
Pull the cover off the motherboard in the back, remove the motherboard and check the solder connections in back of the big power relay, might be burnt.
reggier
#9 Posted : Sunday, January 8, 2012 7:46:41 AM(UTC)
reggier
I checked the back of the motherboard and don't see any burnt solder connections. All solder looks to be ok.
I'm not sure exactly what you are referring to as the big power relay.
richappy
#10 Posted : Sunday, January 8, 2012 10:06:26 AM(UTC)
richappy
If the evaporator never gets ice clogged, you have no defrost problem. Next time it fails, note what is running/not running
Guest (7)
Freezer repair help (Refrigerator & Freezer Repair)
by Stevegefridge 4/15/2013 2:57:36 PM(UTC)
3 Pages123>
