Louis.nicholls
#1 Posted : Tuesday, December 27, 2011 8:34:31 AM(UTC)
Louis.nicholls
water will not stop filling the washer. when spinning has to shut off water valves munualy.
sidfink43
#2 Posted : Wednesday, December 28, 2011 5:39:39 PM(UTC)
sidfink43
Try cleaning out the tube that runs from the water pressure switch to the tub, and if that does not fix things you can try replacing the water level pressure switch.
