Rank:: Member
I have a Maytag frig side by side. Both the frig and freezer are at 10 C. Adjusting the climate controls does nothing. I took the back cover off to see if dust was the problem and noticed that the compressor unit is very hot. The fan runs and the compressor turns on for 5 seconds and there is a "click" and it shuts off. This frig came with the house when we bought 3 years ago and the previous owners said they had trouble with it and repaired it....but do not know what.
Any ideas? Is it worth repairing again...we use it as a second frig. Thanks
Sounds like the compressor starter has failed. I had a Maytag recently doing the same thing which I wrote about in the post Maytag Refrigerator not Cooling on my blog. An easy enough fix and maybe you can keep it running for a few more years.
Rank:: Member
Originally Posted by: TechnicianBrian Sounds like the compressor starter has failed. I had a Maytag recently doing the same thing which I wrote about in the post Maytag Refrigerator not Cooling on my blog. An easy enough fix and maybe you can keep it running for a few more years. Is the start kit in your blog compatible with my model (MSD2356AE)? It looks the same. Thanks
Yes that kit will work on your model as well as many others.
