:eek: [FONT="Comic Sans MS"][/FONT]
Hi. This very ancient machine has gone absolutely psycho. (And the landlord is hiding...) For a few days it will FREEZE everything (including milk & produce) in the lower right-hand part of the fridge. Then it's OK. Then it DIES & THAWS everything in the freezer while bringing all fridge stuff to room temp. Then it's OK. Then it goes back to FREEZING. Then it's OK again. Then it DIES again. And the cycle continues... Much food spoilage & frustration. While the landlord continues to hide. *sigh* Any ideas? Anyone? Bueller? Anyone? Thanks much...
check to see if the fans are running good and check for dust dirt around the compressor if the fans are blowing good check for frost build on the back wall of the freezer then it would probably need a compressor
