3 Pages<123>
#11 Posted : Sunday, September 30, 2007 10:59:14 PM(UTC)
Hi Joseph
What is the model number of your microwave?
Does it make any unusual noises?
marjie
#12 Posted : Sunday, November 18, 2007 5:23:42 AM(UTC)
marjie
I think I have the same issue. My microwave worked fine but made a crackling sound for about two months and now it just stopped heating. Everything else works fine. Any ideas? Do you know the part number is for the magnetron tube for a GE Profile microwave model: JVM1861SD002
Cathy
#13 Posted : Wednesday, December 19, 2007 4:58:21 AM(UTC)
Cathy
I have a Frigidaire Model GLMV168 with above symtoms. Everything works except heat. There is a burnt smell when you open the door.
kawfeeman
#14 Posted : Wednesday, December 19, 2007 5:00:35 AM(UTC)
kawfeeman
Can you check any of the components inside with a multimeter ?
Cathy
#15 Posted : Wednesday, December 19, 2007 5:02:58 AM(UTC)
Cathy
Frigidaire model GLMV168 will not heat. Everything else works and has a burnt smell
Cathy
#16 Posted : Wednesday, December 19, 2007 5:03:40 AM(UTC)
Cathy
Yes my husband has a multi-meter
kawfeeman
#17 Posted : Wednesday, December 19, 2007 5:12:03 AM(UTC)
kawfeeman
if you remove the control panel ( with power off, there should be some paperwork in an envelope ) it will tell you a little about the components inside .. need to check resistance of primary winding of High Voltage Transformer .. should also check High Voltage Capacitor as well ... ( and can also check the Mag Tube as well .. ) this is not necessarily easy and should remember that HV Cap's can store a lot of electricity so try to wear rubber gloves ( how old is unit ? ) sometimes it may be worth while calling a Frigi auth service tech ..
Cathy
#18 Posted : Wednesday, December 19, 2007 5:13:09 AM(UTC)
Cathy
How do I access the things to check. Do I remove the Microwave from the wall hanger or can I access it from the front. What do I check once inside
kawfeeman
#19 Posted : Wednesday, December 19, 2007 5:18:35 AM(UTC)
kawfeeman
open the mic oven door and you should see some screws on the side of the control panel ..
Cathy
#20 Posted : Wednesday, December 19, 2007 5:22:23 AM(UTC)
Cathy
I just called a repairman. Thanks for your prompt replies.
Guest (5)
3 Pages<123>
