darlinlee
#1 Posted : Sunday, February 15, 2009 12:51:27 PM(UTC)
darlinlee
Hi,
I have an older Kenmore gas dryer. It does not seem to be heating as much as it should. It takes 2 to 3 45 min rounds to dry clothes. I have replaced the vent hose cleaned the lint trap out and the inside of the dryer front and back. Still same problem. Please help!!!
#2 Posted : Monday, February 16, 2009 12:10:14 PM(UTC)
Have you cleaned the vent inside the wall all the way to the outlet?
darlinlee
#3 Posted : Monday, February 16, 2009 4:49:06 PM(UTC)
darlinlee
yes it goes straight out my basement window. I have cleaned out all the lint in the dryer. Then lint trap, the front the back and replaced the vent hose. There is no lint issue here.
#4 Posted : Monday, February 16, 2009 4:53:27 PM(UTC)
Disconnect the vent hose from the dryer, and using a meat thermometer, measure the highest temperature inside the dryer vent during the cycle. Do it for all possible temperature settings. Post the results and the complete model number of the dryer.
darlinlee
#5 Posted : Monday, February 16, 2009 4:54:49 PM(UTC)
darlinlee
ok how long should I do this for???
#6 Posted : Monday, February 16, 2009 4:58:08 PM(UTC)
Probably 10 minutes to 15 minutes for each setting.
darlinlee
#7 Posted : Tuesday, February 17, 2009 4:26:37 PM(UTC)
darlinlee
I did give you the complete modle number for the dryer the first posting
Windemere166
#8 Posted : Sunday, February 22, 2009 5:20:46 AM(UTC)
Windemere166
I hope you don't mind if I jump in on this one. My post is Must cycle multiple times to get clothes dry . This is exactly the same problem I am having with a 5 yr old Kenmore. I did the meat thermometer check. It would get as high as ~140 F then the gas would shut off. The temp would get below 120F (lowest temp on my thermometer), gas would come back on. The temp would reach 140F then the gas would shut off. I let it cycle like this a couple of times. The setting was on Normal, timed dry. My serial number is 110.73942101 .
Cotton High - ~150F, 1 cycle then shut down. Have to reset timer to restart
Normal Med High - 140F, multiple cycles.
Perm Press Med - 122F, Multiple cycles.
Ultra Delicate Xtra-Low - ~110F Multiple cycles. (Thermometers scale starts at 120F, had to interpolate).
#9 Posted : Sunday, February 22, 2009 8:54:36 PM(UTC)
Windemere166,
Did you run a full load with the vent hose disconnected from the dryer?
If you did what was the result?
If you did not then do it once and post the result.
The result for the "Cotton High" setting leads to suspicion of failure with the gas valve coils.
Windemere166
#10 Posted : Monday, February 23, 2009 3:12:05 AM(UTC)
Windemere166
The dryer was empty when I ran this test. I will repeat the test today with a full load. Thank you.
Guest (5)
