4 Pages<1234>
rpdugan
#21 Posted : Monday, February 16, 2009 11:44:30 AM(UTC)
rpdugan
i do know from jenn-air that the part number for the hinges changed several years ago... could that mean the hinge also changed??
very frustrating because this is such an easy job to fix....
#22 Posted : Monday, February 16, 2009 12:22:25 PM(UTC)
Usually they change the part number due to new design, but it should fit properly.
rpdugan
#23 Posted : Monday, February 16, 2009 12:31:26 PM(UTC)
rpdugan
They (Jenn-Air) agreed to send me one more set of hinges and recepticals for free, so we'll see later this week of 3x is the charm...
These are the only things that effect this problem, right? Can you think of anything I am missing?
#24 Posted : Monday, February 16, 2009 1:39:05 PM(UTC)
Originally Posted by: rpdugan Go to Quoted Post
...Can you think of anything I am missing?...
No, besides there could be a physical damage to the door frame or the inner door panel.
Keep us posted.
rpdugan
#25 Posted : Sunday, February 22, 2009 5:11:27 PM(UTC)
rpdugan
K..installed the thrid set of recepticals and hinges...so far so good...but I will have to wait a week or so to see if they start to go bad again... But today, all is well...
rpdugan
#26 Posted: : Sunday, February 22, 2009 5:13:44 PM(UTC)
rpdugan
Hey Gene,
How does one know when it is time to replace the gasket on the inside of the oven door? My oven is 10 years old...
#27 Posted : Sunday, February 22, 2009 9:20:42 PM(UTC)
If it's not broken (physically) then there is nothing to worry about.
dhamblet
#28 Posted : Wednesday, June 30, 2010 10:03:20 PM(UTC)
dhamblet
Problem: Wife complains oven door does not completely close on our Jenn Air Oven.
Diagnosis: The pins (which are actually steel rivets) in the hinge pocket are too weak to handle the weight of the oven door without bending. Result is the door hangs open about 1/4" at the top. Even the replacement hinge pins bend quickly.
Solution: Remove the hinge pockets from the frame. Drill out the bent rivets from the crimped side and replace them with cut off 1/4" Grade 5 bolts and spot weld them in. Now the door closes perfectly. If the Grade 5 bolts bend I'll go to Grade 8.
Now wife is happy again.
#29 Posted : Friday, July 2, 2010 2:20:03 PM(UTC)
Just wanted to say thank you for sharing your diagnosis and repair with us. Your post was very informative and instructive.
Thanks again and good luck with your oven.
dhamblet
#30 Posted : Tuesday, August 10, 2010 11:11:27 PM(UTC)
dhamblet
Just wanted to report, its been 2 1/2 months now since I fixed the hinge pockets and the oven door still works like a dream. It hasn't worked this well since we bought the stove new. The original mild steel rivets are simply weak. Maytag/Jennaire should take note but probably won't. I figure they owe me a commission. ha ha
Frigidaire oven door hinge not locking (Oven Repair (including Ranges and Cooktops))
by jacobrobbins219 3/16/2021 5:42:08 PM(UTC)
Where Online Can I Find Compatible DCS (Fisher & Paykel) Oven Door Hinges? (Refrigerator & Freezer Repair)
by WestLA 8/19/2019 10:57:44 AM(UTC)
No lockouts on Gas oven door hinges (Oven Repair (including Ranges and Cooktops))
by sendto 3/16/2018 8:49:42 AM(UTC)
Oven door hinges (Oven Repair (including Ranges and Cooktops))
by prcummings 1/20/2018 3:29:04 PM(UTC)
help with oven door hinge replacement (Oven Repair (including Ranges and Cooktops))
by rick.bain@ferguson.com 4/5/2014 4:20:31 PM(UTC)
Replace Oven Door Hinge (How to) (Oven Repair (including Ranges and Cooktops))
by Tory022 11/8/2013 7:34:27 AM(UTC)
Oven door hinge access on older Magic Chef (Oven Repair (including Ranges and Cooktops))
by sparkyguy 10/17/2013 5:42:59 PM(UTC)
by llfraser 6/14/2013 7:19:47 AM(UTC)
by Ovenblues 4/12/2013 10:39:26 AM(UTC)
Replace GE oven door hinge (Oven Repair (including Ranges and Cooktops))
by C. Renaldo 12/28/2012 7:21:26 AM(UTC)
Whirlpool Oven Door Hinges Continuously Fail (Oven Repair (including Ranges and Cooktops))
by togamac 10/4/2012 8:50:36 AM(UTC)
GE Oven door Hinge - what is wrong? (Oven Repair (including Ranges and Cooktops))
by margot10 7/20/2012 7:00:24 AM(UTC)
Maytag oven door hinges replacement (Oven Repair (including Ranges and Cooktops))
by dennispandolfino 7/11/2012 2:25:00 PM(UTC)
How to remove oven door hinge after door is removed? (Oven Repair (including Ranges and Cooktops))
by stilllearning6 4/15/2012 11:14:40 AM(UTC)
oven door hinge no longer available (Oven Repair (including Ranges and Cooktops))
by itsnotrequired 6/20/2011 9:56:29 AM(UTC)
4 Pages<1234>
