LG gas dryer DLG2241W Gas Inlet Valve Assembly 5221EL2002A Converting from NG to LPG. Have LP orifice 4948EL4002B. After changing orifice, instructions state "Adjust the regulator adjustment screw down to the closed position" I need a better explanation: The large white plastic screw has a thin nut at about the middle of its exposed threads with a blue liquid (Loctite?) dabbed on it. Do I screw it down till this thin nut touches the brass part and stop there or what? How do I know if this is correct.
Originally Posted by: ApplianceJunk ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thank you!
Your welcome. Happy Holidays
