dh12
#1 Posted : Saturday, December 17, 2011 6:19:59 PM(UTC)
dh12
kenmore washer gives f2 code replaced pump and cleaned drain lines still get f2 code
ApplianceJunk
#2 Posted : Saturday, December 17, 2011 6:31:20 PM(UTC)
ApplianceJunk
You probably know all this already, but we have to start someplace. ;)
F2=Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Does it seem to get all the water pumped out in time or does it pump out slow?
ApplianceJunk
#3 Posted : Saturday, December 17, 2011 6:32:07 PM(UTC)
ApplianceJunk
I was also thinking this was a duet, but see you did not post a model number.
What is the model number?
dh12
#4 Posted : Saturday, December 17, 2011 7:18:29 PM(UTC)
dh12
already replaced pump water does seam to drain well but pump continues to run then f2 appears model number 11045872403
problems with washer (Washer Repair)
by zerimar242 10/23/2011 8:27:31 AM(UTC)
Problems with washer (Washer Repair)
by goodangel200 3/20/2008 7:01:13 AM(UTC)
