My two year old washer barely runs water in on any setting- We replaced the water valve hoping that was the problem with no change. Anyone got a suggestion?:eek: Thanks so much!
From the above I assume it is filling but is just very slow. Is this correct? Have you tried different temp settings? Perhaps only the cold or the hot is filling.
Did this machine run OK at this location in the past or are you in a new home? The reason I ask is that many new homes have flood protection valves built into the plumbing, these can cause problems.
Disconnect the hoses from the machine and run into a pail. Do you get good flow? If YES Disconnect the hoses from the taps and run. Do you get good flow? If YES Then I am stumped
If NO You may have a collapsed hose or some hoses have a screen filter built into the sealing washer which may be clogged up. |
THIS FORUM IS DEAD!!!!!!! |
We are in the same home- Its 32 years old so no updates on the plumbing. We have tried different settings, with the same results- The water kind of spurts at intervals into the tub. We will try the hose trick tonight when we get home- I hope it works! thanks for your quick reply!!
