2 Pages<12
#11 Posted : Monday, December 12, 2011 3:16:29 PM(UTC)
Yes Mike, the igniter is definitely bad and hopefully the new part will fix this problem.
You can use the same igniter Part number: AP4091207
platitude
#12 Posted : Monday, December 12, 2011 3:24:55 PM(UTC)
platitude
Perfect- Ordered and on the way. Thanks again for your help - I hope I don't need a new valve- this stuff gets expensive.
#13 Posted : Monday, December 12, 2011 3:28:08 PM(UTC)
You are welcome. I hope so. Keep us posted.
ApplianceJunk
#14 Posted : Monday, December 12, 2011 4:00:38 PM(UTC)
ApplianceJunk
Hi Gene,
Could you tell me how to get a youtube video to display in the forum like you did in your above post?
I have tried using the 'Share' link on the APP youtube channel, but it just post a link to it for me in the forum.
Thanks,
#15 Posted : Tuesday, December 13, 2011 1:18:42 PM(UTC)
Hi AJ,
I posted the answer on your question in the Tech Talk forum.
platitude
#16 Posted : Friday, December 16, 2011 8:26:10 AM(UTC)
platitude
Hi Gene-
I'm installing the igniter, I'm assuming polarity doesn't matter on the wires? I have to clip the connectors off and use wire nuts. Thanks, Mike
platitude
#17 Posted : Friday, December 16, 2011 8:56:30 AM(UTC)
platitude
I installed the igniter. Peak current is now 3.55 amps- a marked difference from the old igniter- it also glowed much brighter. So far everything's working. As for the pulsating flame issue I can see how the failing igniter would cause that but it's too early to tell if my valve is bad too. I guess we'll see as we continue to use the oven. Thanks for your help.
#18 Posted : Friday, December 16, 2011 4:16:16 PM(UTC)
You are welcome. Most likely the problem is fixed and you are prepared for a Holidays cooking.
Happy Holidays!
Guest (12)
2 Pages<12
