mimi
#1 Posted : Friday, November 16, 2007 11:15:31 AM(UTC)
mimi
Door was leaking so I ordered gasket and replaced it. The door still leaks. Latch is tight. Help!
#2 Posted : Friday, November 16, 2007 11:23:10 AM(UTC)
Did you see a lot of suds inside the dishwasher?
okbobcats
#3 Posted : Sunday, November 18, 2007 5:17:47 AM(UTC)
okbobcats
check your spray arms for cracks
allb
#4 Posted : Monday, November 14, 2011 12:19:03 PM(UTC)
allb
How much is too much suds? I see suds in bottom. I'm using the same dishwasher detergent I've always used.
#5 Posted : Monday, November 14, 2011 12:35:38 PM(UTC)
If you see a bubbles, that's wrong.
It can be if you used too much of rinse aid or you did rinse dishes prior to load the dishwasher using a hand dishwashing soap.
allb
#6 Posted : Thursday, November 17, 2011 3:59:39 PM(UTC)
allb
Hello Gene.....In refererence to the suds...we changed float thinking it was causing our front door leakage problem...ran a cycle...water still coming from each side of front door panel. I opened the door and saw suds up to the heating element.....this was with no dishes in the dishwasher and no soap in the dispenser. I've been using Melaleuca Diamond Brite Dishwashing Detergent (liquid) for several years now with no problem. Wondering if there is a soap buildup...or what else I can check. A new door gasket was replaced several months ago by a technician. Any suggestions would be appreciated. Thanks for your help.
allb
#7 Posted : Saturday, November 19, 2011 6:59:42 AM(UTC)
allb
Gene,
Thank you so much for your advice. I finally had a professional look at it....
It definitely was too many suds. He explained what happens in that case. I did my first load yesterday with no soap...dishes were clean...and suds almost gone. I've been using Melaleuca liquid for dishwashers...and apparently too much...for almost 3 years now. I'm not sure why it started doing this now, other than buildup. I'm switching to Cascade powder. Thanks again.
ALLB
#8 Posted : Tuesday, November 22, 2011 5:11:02 PM(UTC)
You are welcome ALLB. I would recommend to use tablets instead of powder.
Guest (8)
GE Cafe dishwasher door leaking (Dishwasher Repair)
by bsikes 9/2/2013 8:32:30 AM(UTC)
GE Dishwasher Door Leaking (Dishwasher Repair)
by ds_05 6/20/2011 5:48:11 AM(UTC)
Whirlpool dishwasher door leaking (Dishwasher Repair)
by R.E.BOB 9/22/2008 9:38:00 AM(UTC)
