My maytag neptune dryer heats up for about 20 seconds with the gas and then stops. it doesn't heat up again after that. what is the problem?
Hi,
One of the two coils on the gas valve maybe failing.
Where is the coils and how do I check which one of any are failing
Yes I did fix the ts error! I'm learning as I go tho ha. But I will try fixing the coils thanks
Your welcome, let us know how it turns out.
oops i had the wrong model number that one is for my washer which has a leak! but the right model number is MDG9700AWW
so this is what I found: The gas is ignited but the flame goes out. If a normal ignition takes place and after a short while the flame goes out, check for the following: • Radiant sensor contacts opening prematurely. • Weak gas valve coil may open when stressed by higher temperatures. • Weak Hi-Limit • Poor venting • Bad drum seals
you think its the coils? am I supposed to replace the 2 coils on the gas valve assembly?
It could be the coils, here is some more info on testing the coils. http://appliancejunk.com...t-dryer-gas-valve-coils/Sometimes they can be hard to test because they may test fine when the unit is cold. Quote:• Weak gas valve coil may open when stressed by higher temperatures.
