cid94
#1 Posted : Wednesday, November 14, 2007 10:00:56 AM(UTC)
cid94
I have a noise during the spin that sounds kind of like a whine/bearing issue. I have replaced the motor coulpler with no change. Any ideas what it could be? Everything works (all cycles).
What's the possibility this is a bearing or the gearbox? Either more prone to failing?
#2 Posted : Wednesday, November 14, 2007 10:44:19 AM(UTC)
The first thing I would check is any foreign objects stuck between the inner and the outer tubs. Also check the holes in the inner tub for the same reason.
cid94
#3 Posted : Wednesday, November 14, 2007 11:23:27 AM(UTC)
cid94
Thank you for you reply. I will check the tubs. However, this definitely sounds like a gear or bearing problem. You can hear it wind down after the spin. It's not a click as if something is in the tubs.
If it's not the tubs, how can I diagnose if it is a bearing or what?
There is no leaking or stains around the gearbox, etc.
#4 Posted : Wednesday, November 14, 2007 11:34:08 AM(UTC)
The next you should check is a foreign objects inside the pump.
