jnibley
#1 Posted : 16 years ago
jnibley
dishwasher makes a loud howling noise that progressively is getting louder. washer works fine but noise is getting worse.
#2 Posted : 16 years ago
You can find some useful information and/or instructions from one of our previous posts: http://forum.appliancepartspros...e-during-wash-cycle.html
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GU1200XTLB0 | AppliancePartsPros.com
iucpa
#3 Posted : 14 years ago
iucpa
Can you help guide me through how to access the motor? I have a similar problem - loud howling noise - disassembled everything I could from the inside and cleaned it all out, but still making almost a grinding noise, so I'm not sure what else to check out.
Thank you!
#4 Posted : 14 years ago
Thank you!
What is the complete model number of the dishwasher?
ED110u812
#5 Posted : 13 years ago
ED110u812
How do I get to chopper? I am having the same noise problem on our Whirlpool GU1200XTLB0
#6 Posted : 13 years ago
The instructions are attached to the reply.
File Attachment(s):
How to replace pump & motor.pdf (1,122kb) downloaded 28 time(s).
ED110u812
#7 Posted : 13 years ago
ED110u812
That worked and I found what shaft holding the chopper and screen was broken. Can you tell me what part that would be for my whirlpool GU1200XTLB0?
#8 Posted : 13 years ago
sPeCiaL eD
#9 Posted : 13 years ago
sPeCiaL eD
I've followed the steps of removal but can't get the inlet protector removed... Help!!!:confused:
sPeCiaL eD
#10 Posted : 13 years ago
sPeCiaL eD
Disregard, got it. I ended up using a Paint can opener tool to snag under the edge near the screw and it finally popped up!
