LuckyL
#1 Posted : Wednesday, November 14, 2007 11:00:09 AM(UTC)
LuckyL
How do you take the outer shell apart to replace belt and idler wheel?
#2 Posted : Wednesday, November 14, 2007 11:45:04 AM(UTC)
Open the door and remove the screw on each side holding the top panel.
Lift the top panel up and remove the screw on each side holding the front panel.
Remove the wires from the door switch.
Pull the top of the front panel toward yourself and release it from the clips.
- The part number for the belt AP2043215
- The part number for the idler pulley AP2043227
- Here are the break down diagrams for the GE dryer Model DHSR333EV1WB
LuckyL
#3 Posted : Wednesday, November 14, 2007 4:14:43 PM(UTC)
LuckyL
Thanks Gene Great directions. They made the task easier.
Thanks again, Lucky
