Fire goes on and off. cold air blows. Single blink indicator light-reads-lockout-check furnace. It appears when you change temp the flame comes on but goes out, does this twice then fan comes on and blows cold. Single blinking light comes on. I then brought temp back down-light off runs fine. Put in new filter-batteries in thermostat, cleaned leads on pressure switch and brown wired relay? Got a new thermostat- Same crap. Can someone help?
hi i am a housewife from Silver spring,Maryland. recently i got the same problem and had nobody to deal with it... my ex-boyfriend advised me to call 301-219-3000 i did it and within hours my AC was repaired By Riley heat&Air experts.. i think they are best you should try them rather than trying to fix it up yourself because they're affordable and expert
We offer all the services you need.As well as repairs & replacements, we also provide furnace repair maintenance services in Reno at affordable prices. For more information visit our site.
