Deanrl
#1 Posted : Monday, November 12, 2007 11:31:16 AM(UTC)
Deanrl
This problem was that it would work off and on. It seemed to help if I moved the unit. Now it does not work at all. I have disconnected the line from the valve and it is clear. The ice maker is still working. Is there something else that could cause it besides the water valve?
Dean
#2 Posted : Monday, November 12, 2007 7:08:54 PM(UTC)
Hi Dean
The first thing I would check if the power is coming to the water valve when you push the lever on the door.
If there is no power then the problem is a bad switch in the water dispenser on the door.
If there is power then the problem is a bad water valve.
Good luck.
Deanrl
#3 Posted : Tuesday, November 13, 2007 4:00:49 AM(UTC)
Deanrl
Thanks! I'll check for the power source before I install the new water valve.
DEan
#4 Posted : Tuesday, November 13, 2007 3:49:43 PM(UTC)
Keep me updated, please.
Deanrl
#5 Posted : Wednesday, November 21, 2007 12:39:40 PM(UTC)
Deanrl
When I had this apart and put it back together, I put vaseline on the electric connections and then in about two days later the unit started working and has been working since. Now I don't know if I should replace the water valve. I think I'll wait a while and see if it keeps working.
Dean
Deanrl
#6 Posted : Wednesday, November 21, 2007 12:42:28 PM(UTC)
Deanrl
I have already purchased a new water valve.
Dean
Guest (6)
