CLHOLTHAUS
#1 Posted : Wednesday, January 28, 2009 2:59:01 PM(UTC)
CLHOLTHAUS
My dishwasher pumps water in and out, but does nothing else. It won't spray water or wash the dishes.
#2 Posted : Thursday, January 29, 2009 3:14:56 AM(UTC)
Here are the parts
Model MDB8750AWW
Here is a service manual and a tech sheet
http://www.servicematters.com/m...ibrary/docs/16022783.pdf
http://www.servicematters.com/m...ibrary/docs/16023227.pdf
From your description I assume the unit runs through a cycle but the wash pump does not come on.
Try to run the diagnostics.
Check at the motor with a meter for continuity
Check at the motor to see if it is getting power
Remove the inner door pane and check the wires from the control board to the motor.
