carlres
#1 Posted : Monday, January 26, 2009 6:25:33 AM(UTC)
carlres
I have a Maytag Refrigerator. The freezer part is freezing fine. However, the refridgerator is not as cold asit used to be. I have turned up the thermostat to see if it would get colder but it did not work.
I notice that there is alot of Ice buit up in the coils and in the area of the evaporator. Also notice the defrost heater to be burned up on one side, I am not sure if its ok.
The fan is working fine. Any suggestions what parts I would need to order.
Thanks in advance for any suggestions.
#2 Posted : Tuesday, January 27, 2009 6:37:39 AM(UTC)
Here are your parts includes a wiring diagram
Model PTB1953GEQ
Here is a good site to help troubleshoot
http://www.applianceaid.com/refrigerator.html
First guess would be the heater. It looks like a glass type and they are a known problem.
The better way is to check it with a meter
I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
