You have been a member since:: 11/11/2007(UTC) Posts: 3
Just wanted to correct the model number for the previous post. 665-17772990.
Hi slangzang
Did any light on the control panel were blinking?
Did you hear any unusual noises prior to the dishwasher stopped?
the no heat dry light blinks. i dont remember hearing anything. If i lift the latch when it does it, the lights will kick back on and start for 5 sec than shut off.
Most likely the problem with your dishwasher is a stuck pad on the key pad. In order to fix it the console has to be replaced. - The part number for the black console AP3097096 - The part number for the white console AP3097097 - The part number for the almond console AP3097098 Good luck. Gene.
