mudbug42472
#1 Posted : Tuesday, November 8, 2011 7:11:18 AM(UTC)
mudbug42472
My kenmore washing machine stops just before the rinse cycle on all three washing options. I can hear a humming noise coming from behind the control knob. If I turn the control know off and on long enough I can eventually get it to work. Any ideas on the solution would be appreciated.
sidfink43
#2 Posted : Thursday, November 10, 2011 5:30:24 PM(UTC)
sidfink43
Well normally your symptons are those of a failed lid switch, but it should not come on after shutting it off if that were the problem. So check out the lid switch just to eliminate it as a problem, and if that is not hte problem try changing out the timer.
