Billk
#1 Posted : Sunday, November 11, 2007 2:30:34 PM(UTC)
Billk
My GE washing machine goes through all the cycles without a problem. However, when it reaches the spin cycles it does not drain:confused:
#2 Posted : Sunday, November 11, 2007 3:07:34 PM(UTC)
Hi Billk
Remove the front panel and check the drain pump.
If it runs but does not drain, most likely there are a foreign objects inside the drain hoses or the pump impeller.
It should be 120V coming to the pump when the timer is set for spin (the lid should be closed).
If there is no proper power coming to the pump and the washer spins, then the problem could be a bad wires or a bad timer.
If the washer does not drain and spin, then it could be a bad lid switch, a bad wires or a bad timer.
If there is 120V coming to the pump but the pump does not run, then the pump itself is bad.
- The part number for the pump AP3193205
- The part number for the timer AP2045964
- The part number for the lid switch AP2620150
- Here are the break down diagrams for the GE washer Model WPSR3100W2WW
Good luck.
Extension hose for GE washing machine GFW850SPNRS (Washer Repair)
by Guest 3/17/2023 9:53:53 PM(UTC)
GE Washing machine water level problem (Washer Repair)
by Guest 12/3/2022 12:53:02 AM(UTC)
GE washing machine leaking help (Washer Repair)
by HotCarl919 6/18/2022 8:12:16 AM(UTC)
GE Washing Machine no lights and will not turn on sometimes (Washer Repair)
by Denver714 3/11/2021 6:58:31 AM(UTC)
Before you replace that GE washing machine control board... (Washer Repair)
by GEfixerupper 10/11/2020 6:25:53 PM(UTC)
GE washing machine wash cycle issue (Washer Repair)
by MrLuke 4/23/2020 11:00:59 AM(UTC)
GE washing machine power goes on and off (Washer Repair)
by momage333 3/29/2020 6:03:57 AM(UTC)
GE Washing machine deep fill (Washer Repair)
by tech07 5/12/2019 5:10:57 AM(UTC)
Help on GE washing machine (model WBB4500E1WW) (Washer Repair)
by charley807 2/5/2019 9:26:42 AM(UTC)
GE Washing Machine Drips When Off (Washer Repair)
by kevin1boyd 5/7/2017 5:48:33 AM(UTC)
GE Washing Machine freezes and locks up (Washer Repair)
by Swilly 8/24/2016 1:39:40 PM(UTC)
GE washing machine wont drain or spin but agitates (Washer Repair)
by Billybrokege 5/14/2015 2:26:58 PM(UTC)
ge washing machine help (Washer Repair)
by dnpro02 3/19/2015 7:57:02 PM(UTC)
GE Washing Machine Making Crazy Noise and Electrical Smell (Washer Repair)
by TripleDigitRide 6/21/2014 8:05:46 AM(UTC)
GE Washing machine is overflowing on super setting only (Washer Repair)
by Ctomanec 3/29/2014 9:53:09 AM(UTC)
