renatodato
#1 Posted : Tuesday, January 20, 2009 11:03:28 PM(UTC)
renatodato
Temperature alarm light is on, contents of freezer are thawing. What part needs to be checked?
Rey
#2 Posted : Wednesday, January 21, 2009 3:49:17 AM(UTC)
Model FFU20FC6CW0
Is the compressor running? Could be a starter or thermostat problem or could be stuck in a defrost cycle.
Are the condenser coils clean?
If the compressor has a fan, is it running?
Are the evaporator cols iced over? If yes then is probably a defrost problem.
If it has a evaporator fan, is it running?
Here is a link that may help
http://www.applianceaid.com/repair-help.html
The refrigerator section has more info than the freezer
renatodato
#3 Posted : Wednesday, January 21, 2009 5:52:06 AM(UTC)
renatodato
Thank you. I'll check those components.
Rey
renatodato
#4 Posted : Saturday, January 24, 2009 12:16:19 AM(UTC)
renatodato
I cleaned the evaporator coils. Now the bottom shelf is working, ie, freezes meats solid.. Top shelves are not working. What could be the problem? I don't see fan anywhere.
richappy
#5 Posted : Saturday, January 24, 2009 12:45:05 AM(UTC)
richappy
Open the freezer door and depress the door trim switch. Does the freezer fan now work? If not, that's your problem.
renatodato
#6 Posted : Saturday, January 24, 2009 8:33:08 PM(UTC)
renatodato
Tested the fan motor. The fan is not working. I'll replace it. Thank you very much for the expert advises.
Guest (5)
