2 Pages<12
blo0omingtonmike
#11 Posted : Sunday, November 6, 2011 8:20:46 AM(UTC)
blo0omingtonmike
Originally Posted by: Joe / APP Team Go to Quoted Post
Mike,
You're doing fine, 2 to 2 1/2 revolutions won't make a major difference, you 'll be fine, especially when you fine tune the fuel air mixture, if needed.
The bake and broil orifices are converted in the same manner, use a 1/2 in. open end wrench and adjust the orifice the same, as the top burner orifice.
joe just wanted to say thank you. SI shoudl be doing the change over here in a couple hours when some muscle arrives and we can get this Jenn air upstairs.
Off yto buy a new hose and a F to M copnverter and a 90 degree elbow.
I will get that oven orifice converted too.
The new control panel worked great! Thanks for selling those too me appliancepartspros!!
Joe / APP Team
#12 Posted : Tuesday, November 8, 2011 6:35:37 AM(UTC)
Joe / APP Team
Mike,
Great, Remember to drop us a line when you're done.
We'll keep an eye out for your post.
blo0omingtonmike
#13 Posted : Tuesday, November 8, 2011 1:42:15 PM(UTC)
blo0omingtonmike
Mike,
Everything worked great. Got the stove installed Sunday. May move my gas line a bit as it hits the back of the range and I cannot put it as far back as I could.
Also I need to check that circuit as I turned on convection and the oven light and I tripped a breaker a bit after the fan started after warm up. May be a weak breaker. I have not had that large a load on that circuit before.
Any good suggestions for hiding the back gap where the stove does not meet the wall flush?
Joe / APP Team
#14 Posted : Tuesday, November 8, 2011 2:08:40 PM(UTC)
Joe / APP Team
Mike,
Glad things are coming along well.
Hopefully it's just a weak breaker or connection, there is a possibility that there could be a pinched wire from the cooling fan, and you may want to remove the back panel and check it first.
There was at one time an insert trim panel to fill in between the counter top and wall. 7706p009-60 is a part number, (if it's still available) and may work for you.
2 Pages<12
