OVen Heats up then flashes error code F 3. Also it does not always get the fault after it heats up.What needs to be replaced?
Are you sure it shows "F10" error code?
My mistake it is F 3 and it does not show the fault every time you use the oven.
"F3" error code means the control senses the oven sensor is open. Replace the sensor and eliminate the sensor plug during the installation. Hardwire the sensor, using the high temperature porcelain wire nuts, included in the kit. - The part number for the oven sensor is AP2023670Gene.
