You are welcome Mark. I'm glad to hear it.
Thanks Gene the information turned a two day headache into a 2 minute fix. You might want to include this info in the packet shipped with the replacement ERC. Thanks again!!!
Originally Posted by: indees ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Gene, Thanks for all your help!!! We now have a working oven.:):) It's been a few years.
Mark:) Thank you Gene! Like mark I did not know how to wire this! did it just as you said.............got a working oven! Thanks again Gene!
Originally Posted by: indees ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Gene, We hooked up all the wires, turned the gas back on and tried to fire it up. It would not ignite. I do not need to light a pilot. It appears the ignitor switch is not working. In the box that I received the part in there was another black wire. Here is picture of the wire. Does it need to be plugged in somewhere? Maybe the relay? Does the relay need a common wire attached to it. On the new board there is nothing attached to the com connection on the relay. Does this relay need a common attached to it to work? piece pictures by rnwcompany - PhotobucketThank You Gene, I purchased the same ERC part Janice had bought and have the same dilemma as she did - another black wire and don't know where to attach it to. There's a diagram that came in the box but it's not really clear cut where to attach it to. I followed your instruction to splice the 2 white wires (it could have been yellow when it was new. It turned to white now) and attached them to the 2 white wires. There were 5 wires for the new ERC as opposed to the 2 wires of the old plug.
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Unfortunately there was not much help from GE. As far as I can recall from my memory this black wire should connect the "L1" & the "COM" terminals.
Gene. Gene, you are correct that the black wire that came extra with the shipment (called piggyback jumper) from the replacement instructions that came in the box connects to the L1 and the COM terminals. Make sure the piggyback (shorter compared to the opposite end of the wire) should be connected to the L1 terminal of the new board first prior to connecting the black wire from the old board. The piggyback has a tab on the side for the black wire from the old board to connect to. The opposite end of the extra black wire should be connected to the COM terminal (K2). I just installed the newly bought ERC board and it worked! Thank you Gene.:) Rico
