DebS0623
#1 Posted : Wednesday, November 7, 2007 2:20:26 PM(UTC)
DebS0623
All of a sudden, once my regular load of clothes is done washing & rinsing, my washer starts making this loud whining/squealing noise as it is in the spin cycle???? I have taken the clothes out & attempted to just run the spin cycle to see if it does it without clothes in it & it continues.
Could this be a belt or the agitator?? I had washed some bath rugs a few weeks ago & for the most part they fell apart (new) and I had a lot of lint in the bottom of the tub... I ran the washer a few times w/o any clothes to clean it all out. Any suggestions. It's about 6 1/2 years old.
#2 Posted : Wednesday, November 7, 2007 4:53:47 PM(UTC)
Hi DebS0623
In order to provide the most accurate advise I need the complete model number of your washer.
DebS0623
#3 Posted : Thursday, November 8, 2007 4:15:49 PM(UTC)
DebS0623
model FWS850RH0
#4 Posted: : Friday, November 9, 2007 12:46:06 PM(UTC)
The first thing I would check (especially after bath rugs have been washed) is the drain pump.
To get the access to the pump (and all other part inside the washer) you have to remove the front panel. Remove screws on both sides on the bottom of the front panel and push the panel down to release it from tabs on sides.
- The part number for the drain pump AP2108084
The drain pump
UserPostedImage
Also I would recommend to check the drive belt.
- The part number for the drive belt AP3867042
Good luck.
Frigidaire washer will not fill. (Washer Repair)
by Elwood44 8/24/2021 12:55:10 PM(UTC)
Frigidaire Washer FWT449GFS1 won't start or fill will water just makes humming sound (Washer Repair)
by lizard2000 7/6/2021 4:27:51 PM(UTC)
Frigidaire Washer Dryer Combo GLET1142CS0 (Washer Repair)
by texashuman 11/16/2020 9:17:08 AM(UTC)
frigidaire washer not spinning out clothes (Washer Repair)
by tadthebass 3/24/2020 8:51:55 AM(UTC)
Frigidaire washer not draining, no high speed spin (Washer Repair)
by Stheemka 3/24/2020 6:39:56 AM(UTC)
Frigidaire Washer FAFW3801LW3 - Just replaced the control board. Washer won't start the cycle. (Washer Repair)
by johnnyboy101 10/4/2019 11:31:42 AM(UTC)
Frigidaire Washer Dryer Combo Not Working (Washer Repair)
by soshea42 7/10/2016 4:10:09 PM(UTC)
Frigidaire washer dispenser magnet (Washer Repair)
by JAbraham 1/19/2016 12:05:33 PM(UTC)
Frigidaire washer won't agitate (Washer Repair)
by goosemasterkl 8/15/2015 9:37:13 AM(UTC)
Frigidaire Washer - No agitation and no spin (Washer Repair)
by jmplsjones 6/29/2015 7:30:44 AM(UTC)
Frigidaire Washer error code 31 (Washer Repair)
by tilegods 5/1/2015 4:15:19 AM(UTC)
Frigidaire Washer will not spin (Washer Repair)
by luvmylars 4/30/2015 11:33:25 AM(UTC)
Frigidaire washer - loud screeching noise at start of spin cycle (Washer Repair)
by Shrimpzilla 4/8/2015 10:25:33 AM(UTC)
Frigidaire Washer "Unique" Leak? (Washer Repair)
by randynavarro 1/3/2015 7:11:35 AM(UTC)
frigidaire washer turns on by itself and floods floor (Washer Repair)
by justin r 12/31/2014 12:32:12 PM(UTC)
