Hi, I can't seem to fix the dryer. I have replaced all components except the coil which heats when direct power is hooked up to it and tests when ohm meter is put on it. Could the control be bad? Thanks
Did you check the therm cut off switch?? that sounds like the problem. f not yes I agree the control time may-be bad.
The therm was replaced too. Anyway to test the control?
