1. Turn on to bake. The lock light flashes. 2. Turn on to clean. It set timer to clean. It heats up and then after a minute it shuts off and flashes f-9
Check the door lock switch, wiring and lock assembly. If everything is good, replace the control board. - The door lock assembly Part number: AP4097943
