rbtlr
#1 Posted : Sunday, January 11, 2009 6:36:52 PM(UTC)
rbtlr
HI. I have a bosh washer that is not letting any water come into the machine when we start the cycle. The hoses have been checked and screens have been also checked they are clean. The washer will spin but no water will go into machine then it will give an error code E02. I know that one problem might be the inlet valves may be bad. But before this all took place the LED display for the time was not working and I was able to get it back working. all lights work and buttons . I was wondering if there could be a problem with LED time board that would cause it not to let the water come into the machine since I took this apart and was able to get it to display again. any advice on this would be appreciated.
Thanks, Richard
misterfixall
#2 Posted : Sunday, January 11, 2009 7:00:14 PM(UTC)
misterfixall
have you made certain the water valve under sink to dishwasher is turned on
rbtlr
#3 Posted : Monday, January 12, 2009 12:08:47 PM(UTC)
rbtlr
yes the water valve is turned on. never was turned off.
Richard
misterfixall
#4 Posted : Monday, January 12, 2009 1:11:41 PM(UTC)
misterfixall
check to see if you are getting 110 volts to valve
Amana washing machine trouble (Washer Repair)
by Freddy76 7/17/2017 2:47:07 PM(UTC)
Washing Machine Troubles (Washer Repair)
by Cale16 6/4/2015 3:09:55 PM(UTC)
Handy DIYer, first timer with a washing machine troubleshoot... (Washer Repair)
by jkbrennan 1/25/2014 10:48:00 AM(UTC)
maytag washing machine troubles (Washer Repair)
by drpetey1 1/8/2013 3:22:09 AM(UTC)
washing machine trouble. (Washer Repair)
by gbumpus 4/2/2011 6:56:39 AM(UTC)
Washing Machine Trouble (Washer Repair)
by SANDRA445 7/15/2009 3:23:42 PM(UTC)
LG Washing machine Trouble code (Washer Repair)
by Paul Cruz 9/18/2008 10:39:46 PM(UTC)
