On my LG front load washer I have been getting trouble code OE.I have checked the pump, filter and discharge hose for blockages and they are clear. Im thinking its got to be an electronic issue? The problem does not occur everytime. If its a circuit board, which one do I replace?
You need to get a service manual, and this site here Search Form - ApplianceDigest.comhas a bunch of LG manuals. You will have to join but there is no cost to join or to download a manual if they have one for your unit.
manual is useless says I need a service call......
Unfortunately that is frequently the case with the LG's manuals.
Sorry about that.
so what the part number for the circuit board, its cheaper than a new washer or a service call so Ill give it a shot
If you will click on your model number you will be taken to exploded views of your machine and you can select the parts you need.
Good luck, hope that fixes things.
