Hupper
#1 Posted : Monday, October 10, 2011 12:48:31 PM(UTC)
Hupper
Over the past 4 to 5 months, my washer would sometimes fail to spin on heavier loads. This progressively got worse and now it won't spin at all. The coupler looks fine. When I went to remove the transmission, only 1 of 3 bolts were in place. One bolt was on the floor, the other was not found. The tranny seemed to be held snuggly by the single bolt. The clutch appears ok. No sign of heating up, or debris. I can turn the inside of the clutch with some effort. I ordered the missing bolt and the spanner wrench to remove the spin basket. I beat on the spanner wrench for a very long time with a heavy dead blow hammer and it would not budge! It surprised me how much force I had to use. When it finally did start to move, after unthreading a little, the basket drive block is moving (slipping) with the locking nut! It appears the drive block is broke, or either it or the basket drive shaft is stripped. Does this sound correct? The spin basket still refuses to come loose. Where do I go from here? How do I get to the drive block? Thanks.
#2 Posted : Monday, October 10, 2011 3:41:28 PM(UTC)
Originally Posted by: Hupper Go to Quoted Post
...It appears the drive block is broke, or either it or the basket drive shaft is stripped. Does this sound correct?...
Yes, it is very possible. Hopefully the following movie will help: How to replace washer drive block.
You also can find some useful information in one of our previous threads: http://forum.appliancepartspros...-washer-brake-shoes.html
Here are the breakdown diagrams and Replacement parts for Maytag MTW5870TW0 AUTOMATIC WASHER | AppliancePartsPros.com
Maytag Washer won't spin or complete cycle - FIXED! (Washer Repair)
by jimjokjv 10/1/2021 10:08:04 AM(UTC)
Maytag Washer won't Spin just Hums (Washer Repair)
by bnweth 1/4/2017 8:29:35 PM(UTC)
maytag washer won't spin fast (Washer Repair)
by benp1 12/21/2016 5:14:31 PM(UTC)
Maytag Washer Won't Spin (Washer Repair)
by DJames 9/6/2015 5:36:58 PM(UTC)
Maytag Washer won't spin. (Washer Repair)
by spectre_ 1/19/2015 5:24:12 PM(UTC)
Maytag washer won't spin fast enough (Washer Repair)
by dster 1/6/2014 7:06:08 AM(UTC)
by ProfKenn 11/21/2013 6:18:07 PM(UTC)
Maytag washer won't spin (Washer Repair)
by ma-henry 11/14/2013 8:43:10 AM(UTC)
Maytag washer won't spin and there is a burning smell (Washer Repair)
by figureguy 4/6/2013 11:59:49 AM(UTC)
Maytag Washer won't spin sometimes! (Washer Repair)
by fixit4meNOW 3/21/2013 11:11:25 AM(UTC)
by treehugger 8/25/2011 12:44:37 PM(UTC)
by erichmann 4/11/2011 6:06:40 PM(UTC)
by randowhite 3/31/2011 11:45:17 AM(UTC)
Maytag Washer Won't Spin or Agitate (Washer Repair)
by scott805 11/16/2010 12:09:40 PM(UTC)
Maytag Washer won't spin (Washer Repair)
by starkdr1 2/27/2010 10:05:08 AM(UTC)
