boboe
#1 Posted : Sunday, October 9, 2011 4:32:28 AM(UTC)
boboe
I have a side by side Model # PSS26SGPA SS and it has stopped both cooling and freezing. Everything seems to be working as usual except the compressor. Could this be a function of the control board or does the compressor need to be replaced? Is there a way to view fault codes and if so how is this done
richappy
#2 Posted : Monday, October 10, 2011 1:22:52 AM(UTC)
richappy
I would remove the motherboard cover, remove the motherboard and check for bad solder joints by the big power relay. If ok, probably a bad motherboard AP4436216
boboe
#3 Posted : Monday, October 10, 2011 3:50:08 AM(UTC)
boboe
Thanks for the response, I will pull the motherboard and check it out.
