It seems that this is a very common problem with this unit by all the posts I've read. My overn no longer turns on. Oven won't light. top burners are fine. Prior to this the oven worked flawlessly. Can I obtain an illistration and service information. All I have is the operator instr.
Model: JGBS23AEA2AA Serial: DV153747P
Originally Posted by: wannafixit ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) It seems that this is a very common problem with this unit by all the posts I've read. My overn no longer turns on. Oven won't light. top burners are fine. Prior to this the oven worked flawlessly. Can I obtain an illistration and service information. All I have is the operator instr.
Thanks With the help of reading multiple posts on similar problems I went with the flow and got an ignitor. The OEM part came with porcelein wire nuts. Repair took 30minutes. Although I had no response back from my innitial post I was able to look up part on an older post in the archives which showed a link to parts breakdown. I've added this website to my favs.:)
