randc
#1 Posted : Friday, October 7, 2011 3:53:14 AM(UTC)
randc
Ice machine will not work I put the lever down and it will not eject the ice, the ice is frozen and 8-9 hours have gone by but will not come out into bin- everything else works fine - the water and the ice coming out into your glass part works great- thank you in advance for any advice
Jeff / APP Team
#2 Posted : Friday, October 7, 2011 6:37:05 AM(UTC)
Jeff / APP Team
Hello. Remove the cover form the icemaker and use an insulated jumper wire. There are two hole one labled T and the other H. Insert the wire into those holes and see if the icemaker cycles. If not, you will need to replace the icemaker. Hope this helps.
Part number: AP2984633
randc
#3 Posted : Friday, October 7, 2011 9:30:26 AM(UTC)
randc
do I put the wire in both holes at the same time and
Jeff / APP Team
#4 Posted : Friday, October 7, 2011 9:35:19 AM(UTC)
Jeff / APP Team
Hello. Yes, but make sure the wire is insulated, and once the wheel turns about ¼ way around, remove the jumper wire. Hope this helps.
Whirlpool Ice Dispenser Auger will not run (Refrigerator & Freezer Repair)
by WhirlpoolDave 4/1/2024 12:44:26 PM(UTC)
Whirlpool Ice Dispenser Auger issue (Refrigerator & Freezer Repair)
by Daveh839 7/11/2023 11:36:45 AM(UTC)
Whirlpool Ice Dispenser loud (Refrigerator & Freezer Repair)
by jbusbee83 7/25/2022 3:46:45 PM(UTC)
kenmore/whirlpool ice dispenser auger motor bad ? (Refrigerator & Freezer Repair)
by bobvance 3/23/2019 3:28:57 PM(UTC)
burning up Whirlpool ice dispenser motors (Refrigerator & Freezer Repair)
by dicktrickle88 6/3/2015 12:05:20 PM(UTC)
Whirlpool Ice Dispenser Problem (Refrigerator & Freezer Repair)
by aggiezg05 3/28/2014 3:57:29 PM(UTC)
Whirlpool Ice Dispenser not dispensing (Refrigerator & Freezer Repair)
by dileas 5/23/2013 11:12:31 AM(UTC)
Whirlpool ice dispenser not working (Refrigerator & Freezer Repair)
by DIM62 1/12/2013 7:44:42 AM(UTC)
Possible Whirlpool Ice Dispenser Leak (Refrigerator & Freezer Repair)
by DJosephSr 11/23/2012 4:21:05 PM(UTC)
Whirlpool Ice Dispenser Repair Kit Compatibility (Refrigerator & Freezer Repair)
by wsb252 3/2/2012 4:39:00 PM(UTC)
Whirlpool Ice dispenser door not working (Refrigerator & Freezer Repair)
by commo 2/9/2011 9:25:33 PM(UTC)
Whirlpool Ice dispenser Freeze up (Refrigerator & Freezer Repair)
by tc88 7/21/2010 9:28:55 AM(UTC)
Whirlpool Ice Dispenser Not Working After Relay Replaced?! (Refrigerator & Freezer Repair)
by davehorner 12/10/2009 10:52:55 AM(UTC)
whirlpool ice dispenser chute door wont close (Refrigerator & Freezer Repair)
by tksnyder 5/22/2009 8:54:24 AM(UTC)
Whirlpool ice dispenser door broken (Refrigerator & Freezer Repair)
by Mwis 5/6/2009 6:30:39 PM(UTC)
