i have a whirlpool cabrio model number WTW6600SB2 that gives me an error F1 and i need help
This is what the tech sheet says on the F1 code Pressure Signal Out-of-Range
F then 1 flashes when the control detects an out of range pressure signal.
➔ Check pressure hose connection from tub to machine/motor control. Is hose pinched or kinked?
➔ If F then 1 repeats numerous times after POWER is pressed and the pressure hose connection is not pinched or kinked, replace the machine/motor control
Hope this helps, here's the breakdown Model WTW6600SB2
Nat
thanks for your help god bless eramcpt
