The compressor is not working. The fan is running,the setting on the freezer is 1, and the fridge is 36. Everything else seems to be working fine.
Your temperatures look OK if anything the fresh food may be a little cold. So your compressor must be running as it is what cools the unit.
I could not find any info on the given model number. Please check it.
Could be that the unit uses a variable compressor with an inverter. Basically the compressor runs all the time but is variable speed. |
THIS FORUM IS DEAD!!!!!!! |
