mkgunnels
#1 Posted : Monday, January 5, 2009 4:03:59 PM(UTC)
mkgunnels
function scrollwindow(){ try{ scroll(0, 50000); }catch(e){}} UserPostedImageThe oven on my ge electric range is not heating properly. I am having trouble turning it on, the preheating light just flashes. Eventually I am able to turn it on. When I do it will not heat to the appropriate temperature. I turned it on to 350 but it only gets to 200 degrees. I am thinking I need to replace the oven sensor or thermostat. I don't seem to be able to find a part listing for the thermostat. My range has an electronic control panel, does that mean it doesn't have a thermostat? My model number is JBP26G S2AD.
kayakcrzy
#2 Posted : Monday, January 5, 2009 4:35:13 PM(UTC)
kayakcrzy
With that much of a temperature difference you need to replace the clock control board. Tom
