The refrig light does not come on (verified bulb is not burned out). Also, the front control temp setting lights are not illuminated. Refrig appears to be working fine otherwise. Can anyone help me determine what part(s) are needed to fix the problem? Thanks in advance.
There are two or three light bulbs in the refrigerator part. If no one light works then the problem is a bad light switch (#8 on the break down diagram). If only one of them does not work and the light bulb is fine, then the problem could be a bad socket or a broken wire. - The part number for the light switch is AP3132744 - The part number for the socket is AP3108436Here are the break down diagrams for the Whirlpool refrigerator Model GS5SHAXNL00Gene.
Gene,
Thanks for the help. I will order the part today. Sincerely I appreciate your reply. Mark
