charles sp davis
#1 Posted : Monday, January 5, 2009 12:16:57 PM(UTC)
charles sp davis
My Maytag gas dryer starts to heat up but then cuts off. The glow coil seems to be working and I get a good blue flame but it only lasts 30 seconds or so. Could it be a bad limit switch?
kayakcrzy
#2 Posted : Monday, January 5, 2009 3:01:06 PM(UTC)
kayakcrzy
It could be a a clogged vent. Check the air flow to the outside. If the air flow is good, here is what I want you to check. When the dryer comes on for the first round of gas, when it cycles off, will it light the second time? If so, you most likely have a clogged vent, if not, replace the coils on the gas valve. Tom
charles sp davis
#3 Posted : Tuesday, January 6, 2009 9:23:56 AM(UTC)
charles sp davis
The dryer and vent is now spotless inside and out. The burner stays on for about five minutes but will not re-light for quite some time.
#4 Posted : Wednesday, January 7, 2009 1:19:05 PM(UTC)
I agree with Tom. Most likely the problem is a bad coil on the gas valve.
- The part number for the coil kit is AP3094251
Here are the break down diagrams for the Maytag dryer Model LDG4914AAE
kayakcrzy
#5 Posted : Thursday, January 8, 2009 4:18:22 AM(UTC)
kayakcrzy
Why it is so nice to get Gene to agree with me. LOL!!! Tom ApplianceEducator.com
charles sp davis
#6 Posted : Friday, January 9, 2009 3:02:10 AM(UTC)
charles sp davis
Sorry men. It was the high limit but thanks for the help.
kayakcrzy
#7 Posted : Friday, January 9, 2009 4:03:07 AM(UTC)
kayakcrzy
The only time I get Gene to agree with me, I'm wrong. I am devastated. Good Job!!! You got it fixed, that is the main thing. Tom ApplianceEducator.com
#8 Posted : Wednesday, January 14, 2009 11:02:47 PM(UTC)
And again I agree with Tom. We are glad you were able to fix it even with not very accurate advises.
Thermador Gas Stove Burner Turns Off By Itself (Oven Repair (including Ranges and Cooktops))
by Guest 3/23/2022 5:15:42 PM(UTC)
Gas dryer burner turns off after 30 seconds (Dryer Repair)
by fairhaven29 4/11/2009 10:01:12 AM(UTC)
