Reluctant Electrician
#1 Posted : Wednesday, December 31, 2008 11:00:36 AM(UTC)
GE Microwave is built into the cabinet. It has the proper clearance and the OEM add-on kit to be installed in the cabinet. THe unit periodically stops heating and the timer will stop and restart during a cook cycle. I think it may be the Magnetron Thermo. I've seen GEs with BAD cavity Thermos that open up prematurely which causes all cooking/timer functionality to stop until it cools back closed. this one is new to me. There seems to be an excessive amount of condensation inside the oven hours after heating a frozen dinner etc.. the fan runs and is intact and the air-flow doesn't seem to be blocked.
???? confuses me. I haven't had a chance to lay eyes on the cisuit board yet.:confused:
#2 Posted : Saturday, January 3, 2009 9:14:40 PM(UTC)
Originally Posted by: Reluctant Electrician Go to Quoted Post
...The unit periodically stops heating and the timer will stop and restart during a cook cycle...
Does it stop and restart by itself?
#3 Posted : Wednesday, January 7, 2009 12:30:31 PM(UTC)
Yes! when the timer stops counting it will restart on it's own. It does not spontaneously start when nobodys around or anything.
#4 Posted : Wednesday, January 7, 2009 4:10:22 PM(UTC)
Most likely the problem is a bad control board but there is a small chance for a suck key on the touch pad too.
The model number you posted does not come up. The closest I found is JE2160WF02.
